Bru
But have you tried it?
No 'cos I might be stoopid but I ain't THAT stoopid!
Petrol goes bang, meths doesn't.
How do they get around HMRC's regulations?
It's ethanol so the same rules should apply as apply to IDA and CDA.
Just bought an Origo Heat Pal as part of my long term plan to move to a swinging mooring.
I know these can burn Meths (or cda completely denatured alcohol) or IDA (industrial denatured alcohol)
The issue seems to be that Meths is ok but smells cos of the piridene added to make it distasteful to drink or IDA requires the issue of a permit from the HMRC to use up to 20litres per year AFAIK.
Have any forumites bothered to take the HMRC/IDA route or do you just buy Meths and put up with the smell ?
Are there any other issues with Meths ?
TIA
Petrol doesn't go bang. But it's vapour certainly will, and that's how you light Origo stoves. Don't please in any way use petrol![]()
I have done that when we had an Origo, but I wonder with this availability of bio ethanol, whether it would now be worth the hassle?
You are, of course, correct ... but I venture to suggest that you ain't gonna care whether it's the liquid or the vapour that just went bang when you're leaping off the back of the burning boat with your hair on fire
As you say, for the love of everything you hold dear, DON'T use petrol in a spirit stove!!!
QUOTE]
LOL![]()
A bit of a faff to fill I found , I will need to decant my BE into a bottle with a small outlet like a washing up bottle to fill it without spilling.
I did check out the amazon deal BB but was concerned that purity is not stated. The B&Q stuff says it is >97%.
I assume the remainder is impurities of various sorts ?
actually this looks cheaper on amazon
http://www.amazon.co.uk/12-Liters-High-Performance-Bio-Ethanol/dp/B004Y1LDN4/ref=pd_sim_sbs_kh_1
I tried using petrol in a Trangia once. Trangia's are also spirit stoves and we were out of meths.
It started off OK, but it was cold. As it got hotter I was confronted with a Trangia with a 2' high flame, rather than a 2" flame. It turned into an issue to put it out as it was difficult to get near. Meths you can put out with water - in this instance I ended up throwing a wet towel over the whole lot and thanked my lucky stars it wasn't closer to anything.
No petrol in spirit stoves. It says no because it's not a very good idea.
Have a look at this petrol/alcohol cooker..........
I've invested nearly £900.00 quid on an cooker that SWMBO repeatedly informs me is a 1/4 of the size and twice the price etc.etc. Of course, she's quite correct, but the Origo really is superb at what it does,where it does it and does seem more superior each time it's used. It's not impossible that others may hold different feelings of course! I wouldn't dream of using anything other than the correct fuel though; that's too daft to consider.
