VicS
No but there are probably sensors for all sorts of things that I have not seen . It doesn't mean they don't exist.Haven't seen sensors for that - have you?
I've checked my switch panel which is virtually identical to the one on the 42 except it does not have that warning light.
Favourite will be holding tank level (if it has a holding tank!). The ones fitted to that vintage were a nightmare - far too small, separated from the head(s) by miles of pipe - guess why mine has not got that type fitted!
There will be a sender unit on the top of the tank. Pull the wire off and the light should go out - or pump the tank out.
