scr0che
Time to replace the orange gas hose in my gas locker - it has 10mm written on it, so which size hose do I buy? 8mm or 6.3mm bore? Guessing the 8, as that's what the Chandler's seem to be selling.
Use the correct size of hose for the spigot.
Did the boat gas speciallist supply that costly MARINE regulator too ?Could not agree more, thanks for the common sense response.
Fyi see attached pictures, boat end looks ok, 10mm spigot, but bottle end - looks like 8mm spigot - and this WAS done by a boat gas specialist when fitted!
I shall use 10mm spigot on both ends and 10mm hose.
You need the correct size hose for the fittings you have, but are you actually talking about a high pressure connection between the gas cylinder and the regulator or a low pressure connection between the regulator and the metal pipework.As I'm buying a new regulator as well, they seem to come with a 3/8 to 8mm barbed hose tail. I look at the connection I currently have and the 10mm doesn't look like a snug fit.
It's a 36' yacht - safe to downsize it to what seems to be a more regular 8mm hose?
Just a point, I always double clip gas hose connections.Could not agree more, thanks for the common sense response.
