youen
From Yesterday Opencpn is unable to download grib files on an Android tablet,do you have the same problem ?thanks
Seems OK from saildocs, I've some nodered which automatically sends an email 4 times a day and saves the gribs to dropbox, just ran it manually >There seems to be a problem with the GFS data, I'm getting no wind data using xyGrib. I do get wave data though
"send GFS:60N,21N,38W,6E|0.5,0.5|0,3,6..168|WIND,PRESS,APCP,TCDC,HTSGW,WVPER,HGT500,WVDIR,GUST,CAPE"
Yes, didn't work on android, got connection failed. But the gribs seem OK, worked with saildocs.Did you try directly from Opencpn?
Same problem here too.From Yesterday Opencpn is unable to download grib files on an Android tablet,do you have the same problem ?thanks
FYI I'm using the latest release of the paid for app from the google play store - so it should be fine. As noted by others, grib requests via sailmail on my mac version all working fine.From Yesterday Opencpn is unable to download grib files on an Android tablet,do you have the same problem ?thanks
xyGrib recgonise there is a problem... Problem for update GFSThere seems to be a problem with the GFS data, I'm getting no wind data using xyGrib. I do get wave data though
I've registered the issue with the OpenCPN for Android Forum - I'll let you know if there's a fix.xyGrib recgonise there is a problem... Problem for update GFS
My guess is that it flows across into however O on Android gets its GFS data
This reply was posted in the OpenGRIBs forum yesterday....I've registered the issue with the OpenCPN for Android Forum - I'll let you know if there's a fix.
