Seastoke
I thought it would be for when put back on trailer.
Yes had one on my arrow boltIt's on inside Roy
If it has a flapper valve as I suspect then yes it needs to be below the waterline
no none return and open hull , we launched in the dart one night to watch the fire works , in the dark half way down the river we had 3 inch of of water , shit myself then realized had not screwed bung in.Wow, lots of posts while I was writing. I've never seen an internal one before but seen many external.
Seastoke, did yours have any non return valve or was it just a hole?
Did you have a deck with sump or open hull ?
not boat now , it was a speed boat.Amanzi has a bung on the outside, You can see it (removed) on the keel. Your boat has a bung on the inside? Why am I not surprised
Hello , what do you mean, sister.I find myself (unusually!) agreeing with Seastoke. I think it is a bung you remove when the boat is out of the water to drain any remaining water out when you put it back on the trailer, and to stop rainwater filling up the cockpit when it's out of the water (which as well as inconvenient puts excessive loads on the trailer and on the boat where it is supported by the trailer).
I suggest you take it out for the first time only when the boat is out of the water. As it is now siezed, the force you need to extract it may well damage either the bung or its housing. Once it is out get yourself a spare (as well as a new one if needed). If you can't find a bung to match, you'll have to replace the whole bung and housing fitting.
Maybe you should change your name to Barnacle Bill.Amanzi has a bung on the outside, You can see it (removed) on the keel. Your boat has a bung on the inside? Why am I not surprised
The above is correct, (remember we are talking small boats) one small boat that has plugs outside is the CJR, it has three, one for each keel, these are used to drain when out of the water, four boats i have owned, Shetland Sealark, Alaska, Icelander, Argo Hellas, all had a bung on the inside, you could swill the deck whilst underway with the bung out, when you stop, water would come in, you have to remember that these bungs were at deck level, they did not drain the bilge area below the deck, some boats have an external bung for this, or it can be in the transom/deck well, if it is in the well, it will also drain underway.But why is the outside part of the drain plug on the inside?
A planing hull at speed would empty the inside if the plug was removed . I'm sure your tender would too if you could go fast enough.
It's possibly a design idea to be able to drain and replace whilst under way ?
You may have noticed , i don't do politics anymore.I mean that we tend to disagree on most things except drainage bungs!(Especially politics.)
Flapper valves only close with positive pressure against them and are notoriously unreliable.
Personally I would not rely on it and would fit something like I have in my ex Soviet boat. I have a small float switch bilge pump ... 12V 7A/Hr SLA battery and a 10W solar panel ... no regulator or fancy bits needed.
Pump sits in the bilge, pipe overboard ... solar panel keeps battery charged ... float switch switches pump on / off as needed.
Using something like that - basically can ignore the flapper / bung affair ...
