Overandunder
Evening. When I bought my boat it wasn't local to me and at purchase its mast had been removed so all and sundry could be loaded on a truck.
This meant I didn't get to check the rig or make detailed notes. I've since worked it out, mostly. Its simple enough - single (aft swept) spreader 7/8 fractional rig with a single cap shroud, single lower.
The bit I'm unsure about is where the cap shroud meets the spreader end. At this point the shroud passes through a bracket with a single allen bolt which creates a clamp - so my question is how tight should this be ? The shroud doesn't make an even angle either side of the spreader (the spreader being a solid aluminium bar that passes right through the mast). Any thoughts / guidance appreciated on how to set these up would be much appreciated.
