One for the electrical wizards:
doug748
1 Oct 2002
UK. South West.
I'm having problems with my bow light.
I am measuring 12.5v at the holder, which is managing to just about light the LED bulb - if you look at it very close. This is a 1v drop from the board which needs looking at. Nevertheless, on the bench I have a very weak motorbike battery at 11.7v and it lights the LED fine.
Back on the boat, I have tried two different lamp fittings and three different bulbs but still the same result.
Any suggestions?
It would appear that you have significant resistance in either positive or negative wire btween battery and lamp holder. With bulb removed you should measure same voltage at the holder as at the battery. The volt meter does not draw current so no drop. You can connect a resistor or lamp in parallel to the volt meter leads to emulate the lamp. Typically 40 ohms or so or a small 6watt bulb.
Dim LED lamp means resistance in wiring. If you can get a connection to the wiring somewhere near the bulb holder then run another wire external from battery positive to lamp wire positive you may see a huge improvement in brightness. If not do the same duplicating negative wire. If neither improves brightness then problem must be between the point where you injected temporary power and the lamp. persevere ol'will
Just a follow up on this one. After dismantling half the boat redoing most of the main board and redfixing all joints, the culprit was a discontinuity in the one metre of wiring from the forward cabin to the chain locker.
Ended up doing it underway, not at sea but away from base, inconvenient.
The wire is in the dry, not under strain and supported in trunking, so no logic to it 😐
I have had 2 cases of a piece of wire not being continuous. First was in a piece of 5 core cable for trailer lights. One core open. Cut it all apart to find a join made in factory before cover was put on with wires just twisted and eventually apart. The other was a main wire to battery on my little boat where it went along edge of carpet. The insulation must have been breached by foot on top or similar. The corrosion set in from moisture and eventually wire parted. Big bulge in insulation as only indication.
Very dismaying when a piece of apparently fine cable is a disconnect one end to the other. But yes it does happen. ol'will
Corrosion in cables is common on boats. Even tinned cables can suffer with associated increased resistance and poor performance.
Water ingress is the usual culprit, and is difficult to 100% stop. Light fittings have to be open to allow pressure difference and water to drain, I suppose. But these vents can let water in too.
The insulation may not be totally waterproof either. UV can degrade insulation also.
Electricity in a saltwater environment is challenging and frustrating. 😡🤔😔
