Onazn genset suddendly dead
tudorsailor
12 Jun 2005
London
zebahdy.blogspot.co.uk
Went to start the Generator which is a MDKBH. I pressed prime first as I always do before starting. It primed but then went dead. Nothing in the remote display.
Battery is 12.8v. Oil is full. Sea cock is open. No change in breakers but flicked them both ways. No flashing lights. No different on genset itself
Could this be a PCB failure?
Can I do anything else to find the problem
TS
jwfrary
2 Dec 2010
Check/change all the relays under the cover usually there's two, plus the duetch plugs of which there's loads! Unplug plug in again before you do anything else!
