pvb
Quite, facts are a bore which just stick around to annoy
Never a good idea to let facts get in the way of the truth![]()
Indeed! But I think the OP has enough info by now to be able to sort the truth from the myths.
Like the truth that you measure the volume of a hull by multiplying the beam by the length.
Time to stop digging....![]()
LxBxDxCoF...... for underwater volume ie displacement..I don't mind, the level of your understanding seems to be trivial. If your ideas are correct it will save marine architects a lot of head scratching.
Lets throw it open, is there anyone else out there who agrees with you:-
- The measure a boat's volume is found by multiplying the beam by the LOA.
Anyone?
Speaking of prejudice.... your views would appear to be based on having owned bilge keeled 'Laurent Giles and Partners' boats.... quite different animals to the Ed Dubois designed boats.... apart from carrying over the internal draining chain locker..Facts and figures are tedious, aren't they, especially if they don't support our prejudices.
Anyone?
Speaking of prejudice.... your views would appear to be based on having owned bilge keeled 'Laurent Giles and Partners' boats.... quite different animals to the Ed Dubois designed boats.... apart from carrying over the internal draining chain locker..![]()
You need to be careful; I haven't made that claim.
Note that I said 'appear'....I always thought the Westerly Corsair I owned had been designed by Ed Dubois...
Well, I'm eager to learn the logic behind post 64:
"Ahem... Westerly Oceanlord's beam is 4.1m, Bavaria Cruiser 40's beam is 3.99m. So which has the bigger hull?"
When I suggested a boat with smaller dimensions overall might indeed have a bigger, heavier hull:
"Ah, right, so the Bavaria is shorter, and narrower, but despite that you reckon it's got a bigger hull
This is why I said your ideas seem to be trivial. Thinking before you speak is better than back tracking later.
There is a lot to be said about hull forms, materials and design but most people take a balanced view. Maybe you are of those folk you yourself have branded as "enthusiasts".
You had not mentioned in this thread that you had owned a Corsair....
You seemed to base your opinions on bilge keelers
Corsairs.. nice boats.. a poor man's Sealord... and reason for the creation of the Oceanlord
That said ... I prefer the Sealord... sub 12 metres... seaberths in the saloon not burgered up by the 'wraparound' non-sense on the port side... and a mast compression post that you can get a grip on.. not some faux teak boxed up bit of rollocks....
The Corsair is listed in my profile.
I don't recall my Corsair having "wraparound nonsense" or a "faux teak" compression post.
Interesting discussion re the internal volume, I think what is being got at is the beam and length measurements only take you so far. Think if a ship was a rectangular shape, it will have substantially more internal volume that one that is a ship shape
Of course that is an extreme and far fetched example but then think about some boats who have their beam carried further to the stern and bows compared to those what have narrow sterns and more tapering bows
If GRP boat x has a bigger internal volume than GRP boat y, but they both weigh the same, then there must (overall) be less material per square whatever, on average. LOA and beam aren't the only figures to take into account, how about height ? Later Ben/Jen/Bavs have higher freeboard than a lot of older boats. Also, beam is a measurement taken at the widest point of the boat, those newer boats have fat transoms, where did the GRP come from to make the fat transom if the weight didn't increase ? It's pretty obvious, if the same weight of material was used it must be stretched thinner. If anyone knows how to make a fat transom without adding weight, my fife would be interested in a chat with you![]()
Yes, newer boats have wider transoms, but the boats I mentioned in post 59 as examples are over 10 years old, and their hull shape is more traditional. Here are plan views of the Westerly Oceanlord and the 2008 Bavaria Cruiser 40:-
They don't look markedly different in overall form.
But are the two internal volumes the same ?
But, as i said, what's it matter ? Is an inch of lightly rolled layup better or worse than half an inch of heavier rolled layup ?
Neither the weight of the boat or the thickness of the GRP mean much, on their own, with regards to strength or robustness.
