archie26
The casting separating the internal galleries of my manifold is corroded at the exhaust end causing a significant water leak from the raw water coolant circuit straight into the top of the exhaust. Didn't seem to cause a problem whilst running, but I've had difficulty getting the engine to turn on the starter on occasions and I suspect coolant leaking back into the engine causing hydraulic lock.
Does this sound like a plausible hypothesis?
Has anybody come across a repair or re condition for this? Or know of a source of spares?
Asap stock a replacement but that is dissimilar, having an integrated header tank, whereas mine has a separate header tank at the alternator end.
Any suggestions gratefully received.
