Beneteau381
They dont use ethanol in diesel.If you have (white) road diesel in the tank, it's got 5% ethanol in it. Ethanol is hydroscopic (it absorbs water) and doesn't age well. It also attacks a lot of traditional sealing materials. If you have "proper" diesel, it will be low sulphur mineral oil with a few additives. "Propper" Diesel is fine and doesn't "age". Any water that gets into the tank will sit at the bottom, so siphoning out a pint or so should prevent proliferation of the dreaded "bug". A liberal dose of biocide will help kill off any residual bacteria. If you find black sludge in the bottom of the tank, too late, you have to clean the tank properly as this stuff causes all sorts of problems when it gets into the fuel lines. (I didn't say "if"). I have a tiny "sump in my fuel tank and there is usually a red powdery deposit here that appears in a clear siphon. I had mine tested in a lab when I first noticed it and it was residue from the red dye used to colour the diesel, together with some "fine inert particulates". (AKA dirt in the fuel)
Last time I had the dreaded "bug" I removed the tank and had it steam cleaned. It then leaked and I had to have to out, steam cleaned and welded up (it's SS). I should have had it tested when it was first cleaned. Lessons learned. I filled the tank two years ago at the end of winter. This year the boat has hardly moved from it's mooring, yet the engine started immediately when I was hauling out.
Condensation is not mythical. Metal tanks get cold in winter and any moisture in the air space will have vapour in it which will condense out as the temperature drops. This is why boat owners are often encouraged to top up at the end of the season. You never get much but it will permeate to the bottom of the tank and pool at the lowest point. Make sure your filler cap seals well, moisture more often gets in when it rains and this will be a bigger concern. I try to ensure my boat is propped up a little down at the bows and slightly listing to encourage rain water away from the filler as well. I also smear a little sealant (blue hylomar or Fernox LSX) around the edge of the filler cap as it's almost flush with my deck. The sealant is easily removed in the spring.
You won't get an engineer to weld a fuel tank that hasn't been cleaned and some will insist it be purged. Good HSAW practise.
