Tranona
The OP is the seller, not the buyer so is looking for information as to the importance of the findings to counter the expected request for a reduction.Can you use the survey to negotiate a discount in the sale price in the region of the amount of money it would cost to undertake the surveyors recommendation. Your rationale would be that if the vendor declines then he is likely to encounter the same issues with any other prospective sale and that you will either have this additional expense or incur a similar reduction from a purchaser later down the line in the event you don't undertake the work. The vendor may just want to take a bit of a hit just to move it on and be free of the emotional distress selling a boat can cause.
Similarly how intent are you on buying this vessel...could be worth taking a few deep breaths to evaluate the balance between you rational mind and emotional mind and go from there.
Good luck Bw
It is a real problem when the buyer's surveyor has overstated the extent of the "problem" without actually bothering to investigate what has actually been done to the boat to prevent osmosis. He thinks he is doing his client a favour whereas it will probably put the buyer off the opportunity to buy a good boat. As others have said higher spot moisture readings are not an indication of osmosis on their own, and such extreme treatment as suggested is no longer considered appropriate treatment, partly because of cost and partly because it is not always successful.
