Oil filter info please
pcatterall
2 Aug 2004
Home East Lancashire boat Spain
I thought I had 6 spare oil filters but on inspection they are the wrong type.
Engine is a 4108 and I bought what I was told were the filters for all this range.
However mine is the screw on type and those supplied were the type that fit into a cannister on the engine.
The one fitted is a delco X 4138E I now have no spare and suspect that getting one in France will be difficult!!
Can anyone supply information on getting a correct replacement or an equivalent part number.
Many thanks
Many thanks
mine used the same filter as the Rover SD1 3.5
Thanks sailorman!! I have just realised that I have made a boob. The 6 filters are correct( I think !) but for the filter!! I had added a label " fit to engine" meaning fit to the fine filter on the engine!!
However I am still looking for the engine oil filter I recall now that I got one which was for some old BL car.
Thanks again
Thanks all.
I think I will order and collect when I get back to uk.
I went back to basics and followed a guide via different engines. The perkins 4108 pointed me to fram 977A ebay then linked that number to Welland power who sell a perkins 2654407 which they say is equivalent to the fram 977A ( and fleetguard LF 699)
I am now tempted to order 10 ( for £49 +7PP) which seems ok and will see me and the engine out!!
Careful, there are two filters: Powerparts REF 2654403 and 2654407, the first is smaller, the second is taller and bigger, though both have the same diameter and thread.
On my engine, the 2654407 would hit the injection pump lever, so I can only use the 2654403
I have these references on file as substitutes for 2654403
FILTRO OLIO PERKINS 2654403
AcDelco PF939, AcDelco SC, AcDelco X21, AcDelco X4138E, Alco SP802, AlfaRomeo 116760603000, AlfaRomeo 140600634601, AlfaRomeo 60507213, AlfaRomeo 605072131, Allis 62703506, ApLockheed AP84302A, ApLockheed AP84303, ApLockheed LK1051, Baldwin BT216, Barford ABP3001575, Bosch 0451103063, Bosch 0451104001, Bosch 0451203009, Bosch 0451203009850, Bosch 0451203194, Bosch 451203009, Bosch 451203009850, Bosch 451203194, Bosch 9181474057, Bosch P3194, Boss 8592441, Boss 9754776, Boss A8592441, Case 1931136, Case 3118119R1, Caterpillar 313361, Caterpillar 3I1296, Caterpillar 649229E, Caterpillar 694229E, Caterpillar 7W2327, Caterpillar 7W6221, Caterpillar 9Y4479, Caterpillar MCF00020, Caterpillar MCF0020, Citroen 5406242, Claas 147223, Claas 1472230, Claas 147224, Claas 1472240, Claas 147225, Claas 1472250, Clark 3679328, Clark 3981923, Clark 6511776, Clark 910535, CleanFilters DO225B, Climax PEC257003, Coopers AZL109, Coopers LSB5110, Coopers Z89, Crosland 2107, Crosland 532, Crosland 630, Daewoo D160552A, Daf 554329, Daf 555329, Daf ABU8542, Deutz 13023284, Donaldson LFP554403, Donaldson P168090, Donaldson P554403, Donaldson P779152, Donit 431087, Dresser 5568656314, Erf P2654403, Facet ML30137, Fiaam FT4863, Fiat 2223218, Fiat 4506839, Fiat 4523873, Fiat 70002503, Fiat 72370000, Fiat 74511629, Fiat 83963907, FilterControl FCL7165, FilterControl FCL719, Filtration FTL1578, Fleetguard LF701, Fleetrite LFR8701, Ford 3963907, Ford 5000513, Ford 505511, Ford 7072637, Ford 74HM6714BA, Ford 87800083, Ford A730X6714BA, Ford C3AE6714B, Ford E8NN6714BA, Ford V34778, Fram PH28032, Fram PH28041, Fram PH2821, Fram PH2821A, Fram PH2821A-1, Fram PH2821C, Fram PH2986, Fram PH4743, GeneralMotors 25011130, GeneralMotors 25011131, GeneralMotors 7984229, GeneralMotors 7984292, GeneralMotors 7984844, GeneralMotors 91097940, Giesse CLH3021, Greyfriars 929S, Greyfriars 931S, Grove 8775918, GUD Z38, Harmo S818, Harmo S866, Hengst H17W06, Hitachi 1930970, Hymac 2700191, Hyster 259264, Hyster 259964, Hyster 3000231, Hyster 300023112, InLineFilters FFR-PH2821, JCB 02/100284, JCB 02100284, JCB 02100284A, JCB 32/100284, Kalmar 1310602, Kalmar 1316602, Kalmar 9211040001, Kalmar PEC114916, Knecht AW66, Knecht FO355, Knecht OC132, Koehring 8030103, Koehring 8320242, Komatsu 20501K1470, Komatsu 6180515130, Komatsu 6810515130, Komatsu Z14OF10044, Kralinator L64, Kubota 7000014653, LancerBoss 8638703, Linde 0009830E00, Linde 0312225208, Linde 312225208, Linde 9830600, Luberfiner PH4403, Lucas G000, Lucas G070, Lucas G085, Mahle OC37, Manitou 133755, Manitou 171548, Manitou 211017, MannHummel W8004, MannHummel W934, MannHummel W940/24, MannHummel W940/27, MannHummel W940/67, MannHummel W94024, MannHummel W94027, MasseyFerguson 1447048, MasseyFerguson 1447048M1, MasseyFerguson 1447048M92, MasseyFerguson 1447982M1, MasseyFerguson 2654410, MasseyFerguson 2654413, MasseyFerguson 2707136, MasseyFerguson 2862642M1, MasseyFerguson 3621011M1, MasseyFerguson 447048M1, MasseyFerguson 836064M91, MasseyFerguson 881304M91, Masterparts MOF61X, Matbro 500018, McCormick 3540049M91, McCormick 701898A1, Melroe 6511766, Merlo D163542, Motaquip VFL135, Motaquip VFL137, Motorcraft EFL493, Motorcraft EFL74, Motorcraft FL329, MotoriVm 41150068, NapaGold 1806MP, Nissan 15208Y9701, Nissan 993021, Nissan 993072, OrensteinKoppel 103857, OrensteinKoppel 1499423, OrensteinKoppel 8001088, Parker PER137, Pegaso 581473, Perkins 2654403, Perkins 2654405, Perkins 2654410, Perkins 901102, Perkins 916579, Perkins 934623, Permatic ELH4126, Powertrain PMFL153, Powertrain PMFL56, Powertrain PMFL56, Purflux LS753, Purolator L30137, Purolator L37237, Purolator PC237, Renault 22714000, Renault 5000686525, Renault 5000686625, Renault 5001845487, Renault 6005019744, Renault 7505702, Sakura C5101, Sanderson FD8NN6714GA, Savara 92840417, Savara SO404, Savara SO580, Schupp SP4400, Sofima S6040R, Sofima S9400R, Soparis CV440, Sparex M3354, Sparex U03354, Sparex U40538, Sperry 9613324, SureFilter SFO4403, Talbot 0075065702, Talbot 35128900, Talbot 75061409, Tecalemit FB2058, Tecalemit FB20583, Tecalemit FB2068, Tecalemit FB5400, Tecnocar R406, Tecnocar R49, Tecnocar R65, Thwaites T2486, TianjinPerkins T64101001, TianjinPerkins T74105021, Timberjack 105113, Towmotor 694229, UFI 2310202, UFI 2312300, UFI 2316200, Unipart GFE116, Unipart GFE135, Unipart GFE181, Unipart GFE196, Unipart GFE295, Valmet YT0512, Vapormatic VPD5004, Vauxhall 17984303, VME 41150068A, VME 4115065, Volvo 11711977, Volvo 484074, Volvo 4840740, Volvo 484874, Wix 312P, Wix 345P, Wix 51015, Wix 51016, Wix 51806, Wix 51806MP, Wix WF15P, Wix WL7114, Woodgate WGL2821, Yale 440054600, Yale 515133856
