Oil Filter for 4108
pcatterall
2 Aug 2004
Home East Lancashire boat Spain
Supposed to be going down the Mersey on Sat en route to our Conwy mooring. All planed, all fine then the starter packed up. Had to remove the oil filter ( so oil will be changed again!!)
Forgot to bring the old filter back and only think there is a spare on board ( but need a spare anyway) Manual is on board too so you can gues the question!! What filter can I specify to my local car shop please??
Found another problem this was with an injector pipe connection, noticed a small drip which I couldnt 'nip up' started to think I would strip the threads if I used any more force, inspected threads and flare seat, all looked good but still quite a drip. Any tips please? There are spare injectors which I could try, are there any issues doing this??
Thanks as usuall.
Found another problem this was with an injector pipe connection, noticed a small drip which I couldn't 'nip up' started to think I would strip the threads if I used any more force, inspected threads and flare seat, all looked good but still quite a drip. Any tips please?
you will probably find that the pipe has a hairline crack, number one normally goes first.
Number 1 is the front injector, it is a well known problem. it is almost imposable to find a hairline crack, try a.s.a.p. for new pipes
