Oh bugger 2
Funny you should say that, 'cause it was precisely my first thought while reading your update.
Otoh, bearing in mind the 30-50% mortality with the old method, the new one is bound to be better, I reckon!
And after all, nowadays even new planes are flawless upon their first test flight.
No reason why also your op shouldn't fly equally well, so to speak! :encouragement:
All the very best.
I wouldn't use that analogy at the moment, think Boeing 737 Max! The new machine/procedure sounds like a no-brainer RD, things are looking up all the time just a little more patience required. You'll soon be enjoying your boat to the full I'm sure. Good luck :encouragement::encouragement:
Sounds like more positive news RD so fingers crossed for you
By way of an update, a few weeks ago went to Son's wedding thinking it would be the last thing I would do, made it as far as the meal when I had to give up, in the photo's I look dead already.
At this point my top surgeons had given up as had another two top guy's. I was simply to full of high pressure blood which was beginning to burst blood vessels & escape through the fistulas I had.
In recent weeks I have been in & out of various hospitals under a Dr Farooq Rahman who I met while under top surgeons, who has not given up. While not a surgeon he has been project managing me & after many running for the hills as I was getting through about 8 units of blood each week he found a Dr Nasir Khan who is an interventional radiologist.
He first went in through the groin & cut 70% of the blood flow to the spleen which reduced pressure & hence bleeding but not enough, so in a second 4 hour procedure he closed the spleen down completely & also shut off every leaking blood vessel he could see, now nearly perfect, going back in on Wednesday for one last blood vessel & then the bleeding should stop completely & I have already cut out the blood pressure pills as it dropped into my boots, as Farook said.
He now has the best bowel guy in London & a top liver transplant surgeon looking at the op I have so badly needed for so long.
So far I owe a massive debt to two men, hopefully soon to be four, not out of the woods yet but getting there (I hope)
Oh boy, you have really been through it.
Let’s hope you are now on the right track, certainly sounds like you have some top guys on your side.
All the very best.
Pancreatitis leading to intestinal failure & every complication in the book pancreatic pseudo-cyst, portal hypertension, sepsis etc. All started with a misdiagnosis at Southend hospital for gallstones.
Rubberduck, I will pm you tomorrow am after getting to work. Nearly lost a friend to something similar with the same endless aggressive surgical interventions. I can give you the name(s) of the surgeon(s) tomorrow, some of whom may have a useful input. I recall a team at St Thomas’s to be at the absolute forefront in several of the areas which appear to be troubling you. As I remember a professor Jeremy Sanderson made an extraordinary contribution to her care.
Will revert and may god be with you.
Blimey....that’s enough hey!
If they thought gallstones....surprising they didn’t investigate pancreatitis. Stones usually the cause of it as I understand!
Hope they can chop the offending bits out and get you on your way :encouragement:
Thanks, I think he will be known to the Guy's I am with as he shares hospitals, more experts the better, thanks.
Best wishes to you.
I'm sure there are many who think we have problems till you read something like this .......
I can't think of a better way to summarize my thoughts after reading your update, RD.
May the force be with you!
