Oh bugger 2
By way of an update, we are now waiting for a new machine which enables surgery with virtually no bleeding, uses super heated solution which cuts to as little as .3mm depth & cauterise at the same time,has settings for liver, bowl, pancreas etc. Will make procedure much safer, mortality down from 30-50% to near normal. Will be available around June.
In the meantime going to get the boat back in Essex so I can use it locally, south coast is too far at the moment. Bit of a bummer virtually righting off another year but light at end of tunnel, with luck.
Fingers crossed for you RD and I hope you manage to get a little bit of enjoyment from your boat.
The new option for surgery sounds positive and getting the boat to the East Coast sounds like a good move as you will be able to use it. Wishing you well for the surgery and hoping that you get some time on the water.
