moonraker 36
try white star liners.. for info.. their great at crossing the ocean!
I still believe it can be done either with overloading the boat or towing a tank.
Would a cat be more fuel efficient?
Thank you for the comments and the advice. By the way, this is not a troll. I like the idea to treat it as a theoretical exercise and let people decide for themselves if they want to take this "unreasonable" risk. Just a couple of comments though:
1. The idea here is to cross for a min amount of time. If crossing at hull speed then a sailboat is a much more reasonable choice and then the Pacific is a more interesting ocean (you end up somewhere nice). I have done Newport to Bermuda once in 47' foot racing boat and once in a 30' cruising sailboat. Both times the wind did not exceed F4 and it was pleasant except for the extra effort on the racing boat where we had to change the sails every 4-5 hours to eak out the max performance so we did not sleep much. So, if the weather is cooperating, I do not see the problem. If anything I see crew tiredness as a bigger problem. Given our objective to do it in less than 8-10 days, there is a much higher chance of getting a good weather window than crossing at hull speed in 25 days. The outboard motor will be a backup in case the main engine breaks down (in that case we would dump the excess fuel to balance the boat better). We are clearly going to have a watermaker.
2. I agree that may be a bigger boat will reduce the risks substantially, so I will look into relaxing that constraint. Something in the 35' range becomes a lot easier but then the fuel requirement multiplies.
3. We have taken into consideration the fuel distribution, the need to manage the tank volume, the freeboard and so on. All of this is manageable but I agree that if we hit bad weather in the first 3 days when the boat will be most overloaded, it will likely break into pieces. However, we believe that we would only launch if we have a solid favorable forecast. Any forum members that have overloaded their boats 30%-50% willing to share their experiences on how easy it is to maintain 15-20 knots in F4 to F5 conditions with the typical long period ocean waves?
Again thank you for the advice, very valuable and may dissuade us at the very least.
Gushter
To dump the excess fuel??? If you had asked the fish, they would think you are a horrible killer and tyrant.Thank you for the comments and the advice. By the way, this is not a troll. I like the idea to treat it as a theoretical exercise and let people decide for themselves if they want to take this "unreasonable" risk. Just a couple of comments though:
Gushter
