piratos
I struggle to answer your comments though, 'cause I'm not sure to understand them.
Did you by chance mean roll amplitude (or period), rather than acceleration, when you said it's higher in a Nordie?
And re. ultimate stability, are you suggesting that it's lost at a higher or lower degree in a N., vs. other boats?
The point of the comparison among a 40' N. and a sportcruiser rolling adrift in a F4/5 also puzzles me.
Otoh, if you really think that it takes 10 minutes for either of these boats to settle and become uncomfortable, I understand why you are interested to read about that on a magazine...![]()
What I say is that a high boat (Like the Nordhavns) start rolling early. They will quite early reach a higher degree of rolling than a lower boat (like the sportcruiser !)
The Nordhavn has a high end (ultimative) stability, dont expect them to capsize :encouragement:
As to the comparison you really seem to have misunderstood me - what i say is that the sportcruiser will roll less (degrees) lying dead in the sea than the Nordhavn. If you have never tried it, do it. First your boat will roll a lot and after a while she will actually settle.
One more issue that has not been mentioned. A Nordhavn has a huge amount of tank capacity (for its size).
There is a very big difference whether you calculate the stability with full or empty tanks. A Nordhavn has ballast to compensate the hight. Your boat may have a nothing or little ballast - the weight is spread all over the construction (with is good)
Imagine a coaster of say 5000 tons loaded to her marks with steel. The steel will barely fill more than the bottom of the cargohold - that same ship behave totally different if loaded homogenous to her marks with bulk cargo (grain, coal etc)
One final issue. I am not saying that stabs / gyro / stability tanks are not improving comfort. What I am saying is that with Nordhavn you probably cannot live without.
