rptb1
Tammy Norie https://tammynorie.wordpress.com/ has a cunning fold-away sink that drains through 3/4" flexible pipe to a seacock on the starboard side. The sink isn't much above the waterline, and if I forget to close the seacock it spills into the starboard under-seat lockers and then to the bilge. None of this is critical -- the starboard locker contains the flexible water tank, and the amount of water ingress is small -- but it makes the boat wet.
I'm wondering if it would be sensible to fit some sort of non-return valve in the sink drain pipe.
The idea is just to stop or reduce the amount of water that backs up if I forget the seacock. It doesn't matter much if it fails to work or is imperfect. It'll just save me on those occasions when I up anchor and start sailing before I remember about it.
A valid answer is "just don't forget your seacocks idiot".
However, any advice, experience, or pointers to relevant valves would be appreciated.
