No slip deck paint removal
rumtoddy1
29 Jun 2009
essex
Any ideas out there for an easy way to remove old and baked on international deck paint from a grip deck.
I have just tried a tungsten carbide scraper and this is not really touching it. Something a touch more aggressive is needed.
All suggestions gratefully received.
You have my sympathy.
When I had to do it I tried every kind of scraper and all soon blunted due to the grit in the paint.
Eventually I had to use paint stripper, and a hell of a lot of it.
I recoated with Hempel-Blakes Multicoat with non-slip granules added.
I wish I hadn't because it is useless and after less than 2 years it is starting to come off.
I am one who hates trying to strip old paint.
If the old deck paint is still adhering well ... why strip it off ? Get yourself a large can of exterior wall paint such as Fine Sandtex and paint over the old benefiting from its non-slip surface and the new paint putting the colour back ...
I can recommend screwfix ‘no nonsense’ paint stripper. It works it’s way through slowly but doesn’t damage epoxy underneath. You need to leave it on a few days though to allow it to work If you have a thick build up of paint.
Problem with most liquid paint stripper - they attack GRP ..... and need to be fully washed off before any other work done.
Sniper mentions 'epoxy' ..... most GRP boats are Polyester - not epoxy.
apply thin polythene over the stripper to keep it moist & working, once its dried it no longer works
I removed mine with a random orbit sander with 40 grit pads and also a tungsten carbide scraper. However, much of mine was in poor condition. I wasn't fastidious about removing it down to the grp though, when it was adhering well I just took of the top layer. It was hard work.
