Nitromors, the GRP killer
tome
28 Mar 2002
kprick
www.google.co.uk
Boats out of the water and I thought I'd tidy up the topsides. There's a thick blue line running along the top of the hull which has become a bit scruffy ( flaky paint etc).
I've spent many hours rubbing it down in preparation for a profesional spray job, but still there's loose paint. 50 sanding disks later, shold I apply Nitromors to strip it or will this be the kiss of death to the gelcoat?
No getting your own back for any of my recent posts!
Regards
Tom
extravert
20 Jun 2001
Not far from Uwchmynydd, near Bwlchtocyn, just up
This year I have chemically stripped all the below-waterline paint off my boat. The advice I heard was never use nitromors of fibreglass because it will damage the gelcoat, so I didn't try it. Instead I used International Interstrip which does exactly as it says on the tin, ie strips paint from fibreglass without damaging the gelcoat. My bottom has come up like new, although it was lots of hard work.
As there are special paint strippers for fibreglass, why not use one of those? Interstrip comes in 750ml tins for about £12. There's also another common one called Dilunet, but I had less success with that. It's about the same price.
WayneS
21 Jan 2002
Hampshire
I have used it before.
Just make sure you remove any splatters and do not leave it on too long or it will damage the gelcoat.
Wayne
oldharry
30 May 2001
Nitromors is formulated to remove oil based paints. Polyester resin is oil based, therefore Nitromors will go on to attack the Gelcoat.
It MAY be possible to get away with it - but why take the risk on your expensive boat when there are strippers specifically designed to work on GRP?
tome
28 Mar 2002
kprick
www.google.co.uk
Thanks to all for your responses.
I talked with Peter Furby who gave me a contact at Blakes (Peter also thought that Nitromors would be harmful to the gelcoat, and that using abrasives would damage the gelcoat around the blue sheer line).
I also tried looking up Striprite, but could only find reference to bead-blasting abrasives.
I'll talk to Blakes Friday and post any useful advice.
Mirelle
N/A
30 Nov 2002
Do you mean to say....
That the way to get rid of a plastic boat is to paint Nitromors on it?
I knew the stuff was good for something!
tome
28 Mar 2002
kprick
www.google.co.uk
Re: Do you mean to say....
There's a similar product for wooden boats called Gribble...
...but I don't want to open a can of worms!
tome
28 Mar 2002
kprick
www.google.co.uk
Re: READ THE LABEL!!!!!!
Clear to see if you have a tin in front of you!
In the event I used Ladlows Safe Stripper, various scrapers, an orbital sander and 65 disks of 180 grit. Plus over 50 hours of elbow grease. I was grateful for the shower facilities at Emsworth as I started to resemble a monster from the blue lagoon, covered from head to foot in blue powder.
Boat is now ready for topside spray and am now WOW (waiting on weather).
Thanks to all for your replies
