Wansworth
On the point of buying said car,anybody have constructive info,seems to use a lot of fuel!
Most people I know with Landy products rate them very well dynamically, but think they are a nightmare on the reliability front.
We used to regularly hire the Ford version in the late 90's.... The Maverick.
The Terrano shouldnt be compared to the Xtrail/Freelander/CRV... it is really a generation earlier..
In terms of their position in relation to simular vintage small 4x4's... I think it was the best all rounder. I used to have a Frontera (Dont tell anyone....awfull) and we also had 2x 200 tdi Defenders (110 and 90) and a Disco as well....
Compared to my inlaws earlier vintage Suzuki (Lakeys is a much better new one!) it was a much nicer drive... Compared to the Defenders it is a more refined drive on road... but less capable off road... the Disco was better on and off road.. but less reliable and with less cargo space in the rear.
(BTW I am talking about the long wheel base)
The Terrano is a proper 4x4... IIRC it had a live rear axle which limited it a bit... but it had excellent clearance and was surpirsingly capapble off road... (The short wheel base surprisingly so...) Later in its life they started putting power bulges and sidesteps on em and this detracted from them as far as i am concerned....
It was comparable speed wise to the Disco or the 110.....
I dont think its a good Ladies 4x4 simply because its a bit thirstier than modern equivilants... and will be potentially easier to roll, and will oversteer in a lift-off throttle/ wet road situation...
(I had one sideways once... not intentionally and not a good thing..)
A great capable truck if you want a proper truck... but I would go for a xtrail, Rav4, New Vitara, or simular for the wife.
They really should be compared with the LR Defender or Disco.. or the Frontera or early Cherokee....
As we used to short term hire our I can not comment on reliabilty, but the only real dog we ever had was the Frontera. (Which should have been strangled at birth... and I should have known better...)
hmmm... took me so long to compose the reply that youve gone out a bought one....
That's folklore based on either the petrol based rover engines that blew head gaskets for a passtime and had cylinder liners drop into the block causing catastrophic nasties and/or the old smoky joe D1 Rover Diesels.
Td5 and Td4 owners with electrical gremlins are the new black.
Oh, and drivetrain problems with Freelanders.
I'm not saying they are not great machines, but Jap cars do seem distinctly more reliable. Having said that a farmer I know who sold his Defender because of electronic problems bought a Nissan which was absolutely reliable, but then got another Defender because he likes them.
(and anyone can turn any 4x4 over without a great deal of effort)
Honest John quite likes the Freelander. But read the What's Bad section.
A lot of transmission problems have been caused by bad servicing, wrong transmission oils being used and garages simply not understanding the transmission. The common dealer advice in the US has been to replace the transmission when the faults have been actuation solenoids. The 4x4 element of the Freelander transmission depends on a Viscous Coupling and is not fully mechanical. Most drive going to the front wheels in normal driving. Just like the Rav4. The Honda CRV depends on an oil-bath LSD in the rear diff, so it is mechanical.
When Defenders are working properly they are wonderful workhorses. But if you don't need to tow plant trailers over boulder-strewn hillsides, Jap tanks are cheaper and more comfortable. Just my opinion.
Well you're the one doing the arguing.None of this has anything to do with the original thread and is just arguing for the sake of it.
