jfm
Well I reckon we have it covered on the mullion front!
Not sure SWMBO would be too keen on the ton of water test though
Eek yes I suppose people don’t tend to go on about their qualifications/professions. But yes I have a degree from imperial and early part of career in mech eng with a lot of fea and structural work.I didn't realise you were a Structural Engineer
Loverly engines. KISS.Thanks Paul.
Done a lot of work on her since you looked at the motors. Next phase is underway - engine bay re-furb and some changes that meant it was worth taking them out so they can have a bit of a spruce up too.
Low reving proper diesels with lots of litres (6) and loadsa "grunt", plus simple andcheapinexpensive to maintain .
Even have a little built in hand pump , making it easy and clean to carry out oil changes.
From memory the oil filters were upside down so oil drained out of the canister , making filter changes quicker and cleaner.
That heat exchanger is also simple to get at/work on and the internal tube stack is very basic affair.
Noticed that VP have over time increased the cubic capacity of smaller engines, presumably they can no longer squeeze any more reliable power out of the original sub 4 litre block.
Current money pit has a pair 4 cylinder stone age mechanical Yanmars, sadly lacking the cubes of the Perkins.![]()
Yes indeed. Only slight downside is that the engine bay is a bit tight and changing an impeller on the port engine requires the arms of a gibbon and the flexibilty of a ballet dancer. Unfortunately, whilst I have the former my ageing carcass most definitely doesn’t have the latter!
