MGsailor
New Member
"I used what I think they called 'cold start procedure'. Pulled the stop lever up. Put the throttle on full and engine in neutral. Push the stop lever down and push start button."
I don't think you have that in quite the right order. As I understand it, pulling out the stop lever advances the fuel rack and increases the fuel to the cylinders. To get the full effect, this should be done AFTER setting the throttle to (in my case) half to 3/4. So it's set throttle, then pull stop lever out and back in again. That's what works for me anyway.
