Used to have a Monterey 250 with only 1 240hp Yanny in and 27ft long that used to plane about 17/18k but needed trim tabs to get her over the hump. You should be good for 33-35k+ I would have thought with 2 and 29ft. Make sure your legs and trimmed down until she is planning. Mine was on a Bravo II leg and that engine and leg combo is known for taking out prop bushes.... if you think you have a drive issue. but not sure what you have.
Mind you with two 240s sat astern, she probably (as has been said) does need trim tabs down to get her nose down. I would get these working first.
Now you have me worried as I'm assuming that 'prop bushes' being taken out would mean the props not delivering the power, which was what seemed to me to be happening. I am sure that I had the legs fully down, although my boat doesn't have a gauge showing the angle. Being optimistic how do I exclude this possibility?
I had a prop bush go on mine and I could only get to 12 knots - then the engine would rev right up but no more drive. BUT... thinking on I also had a cable problem where the forward drive was not fully engaged and this allowed the cone-clutch in the Drive to slip and I got the same symptom as with the prop failure - I thought it was yet another prop gone, until we looked at it. The first issue was solved via a new prop (a failed bush is visible up close, you can see small peelings of rubber at the edge of the bush (well I could on mine) the second issue was solved by re-adjusting the the throttle and drive linkage and cables. Could it be that one of your drives only is not pushing - so both engines are revving fine, but only one drive is driving properly.
BTW - these props can re-bushed - I had one done to act as a spare - costs about 30% price a prop. Though the process can split the hub...apparently.
Now, that hurts.My son says that we forumites are a bunch of boatachrondriacs and I should stay away from the forum
I guess you mean with some choppy sea (a couple of feet or so), which is in fact also the optimal condition to achieve max speed, counterintuitive as it might seem.
Surely not in any sea rough enough to make slow cruising "too bumpy to continue".
Now, whether that can be found in the Solent, that's a different kettle of fish of course. I didn't think of it 'cause I don't know those cruising grounds. Surely, looking at the map the fetch seems shorter than what I have on the lake...
Do you mean sometimes?I said, Not always of course.
NOT ALWAYS FFS. Thort I'd already said that.
and I should stay away from the forum, but I think I might have an addiction problem
All,
Is there a rule of thumb of what conditions are OK to power up? I'm currently assuming that wind of < 10 mph and sea state of calm is required, but am I being so conservative that I'll never see that in the Solent?
My boat has 2 x 240hp Yanmars and the hull is about 29'.
All advice appreciated.
I ask because a few weekends ago we left Portsmouth Harbour headed to the Isle of Weight straight into a strongish head wind and the ongoing waves and I couldn't 't seem to get her on the plane. Nose went up OK, engines sounded normal, lots of wash but it just didn't seem to want to plane and it was too bumpy to continue. The only difference from the last time time was the wind and the fuel tanks are now half empty.
