rob2
Unless Michael has made significant modifications, then the engine compartment effectively runs back to the transom and is open to the bilges. Like others, I don't believe a fan will make a jot of difference to the temperature in the engine compartment. Consider how cold the seawater being pumped around the engine starts out - a fan can't match that. Also the engine pumps far more air into the compartment than any fan, admittedly by ingesting it, but it will cool anything in its path.
I guess if it concerns you, you could fit a blower and duct it onto the alternator as that is the component most susceptible to damage through overheating.
Rob.
Rob.
