michaela
New Member
I bought an old sailing boat with an old volvo md6b (10 hp) engine, which I've grown attached to, having done about 90 hours of motoring with it when travelling around Holland with the boat, and bringing it back to the UK this year.
The engine cabinet is very close fitting and I have measured the air temperature after running the engine for short time intervals and it is very hot. I have fitted an rpm guage and don't run the engine at greater than 80 percent of its max rpm . Because of the close fitting nature of the cabinet I'm convinced that the engine air supply needs to be improved. I could do this by fitting louvres but if I ship a load of water I don't want the engine to be under water. Also by making holes in the front of the cabinet I'm going to be screwing up the sound insulation.
The engine sits under the cockpit sole and is isolated from the side lockers. The boat is a Varne 850.
What are my options? Preferably low cost as there are multiple other boat things I need to spend my money on (under the wifes radar).
