yelbis
Hi
I have just had a new engine fitted. I have had the boat back a week and the cranking battery was flat. It read only 1 volt. the engineer pointed out that the red isolator handle/switch within the cabin was left in the on position and hence the power drain.
Previous to this I have left this in the on position for the last three or four years. Does anyone know if the engineer is correct. he said the control panel for the 3ym will always be drawing power and that the on/off switch (no key) that is on the front control panel is only to illuminate the back lights. Seems a bad design if this is the case as obviously should I forget then i will always end up with a flat battery plus keep running down an otherwise good battery.
