KompetentKrew
My boat has a pair of running backstays for the inner foresail, which I've never used because I'm afraid of them and of breaking something.
A couple of times recently I've been reminded of the old adage about reefing early, and I'm starting to feel that I really should be using the inner jib rather than the genoa. I've been using the genoa partly furled, and it just seems wrong (I'm probably causing excessive wear to the genoa), especially in a bit of a blow.
What should everyone know about running backstays, to be sure of not breaking things, please?
The boat is a Van De Stadt Caribbean 40, and I have recently been mindful of a conversation I had a bit over a year ago with the proprietor of Gosport Boatyard. He is not a garrulous man, but remarked that my boat has a "big stick" and that I should be sure to reef her in good time. Indeed, I have learned that she can be terrifying if over-canvassed.
I guess it goes without saying that the genoa is masthead and the inner jib is fractional - the inner jib is attached at the upper spreader, 2m or 3m below the masthead. Next to them is also attached a pair of running backstays which are parked on the toe rail, a couple of metres behind the shrouds, when not in use. I'm given to understand that I unfurl the jib, get the boat under sail and then bring the appropriate backstay back to a hard point near the cockpit (outboard of the sheet winch), or is this the wrong way around?
As always, I appreciate any advice.
