paulburton44
I am fitting a new skin fitting below the water line !!!!
I read the bit in pbo a couple of months ago.
It suggest a ply backing plate. If there was a slight leak would this piece of ply not absorb water and delaminate.
The skin fitting does have a large loose washer that will spread the load ??
The hull is 14mm thick.
Now i have drilled the hole would you suggest I epoxy the hole due to the now expossed glass, before installing the skin fitting ?
When i do fit i will be using underwater flexable sealant !! would you add epoxy inside ???
Thanks Paul...
<hr width=100% size=1>www.withamsailingclub.co.uk
Thanks Paul...
