Robin
Just one word of caution.You may find that depending on your length of waste pipe that the fixed electrical pump period may not get your discharge out of the pipe.On my boat the exit and inlet pipe are in a weird position under the bunk in the main cabin.This means that there is about 5m of pipe between the toilet and the exit stopcock.(Why it was designed like this who knows).On my boat it is a standing order that a minimum of 15 pumps of the handle of the Jabsco to make sure it is clear.I asked about this at the Boat Show and was told that the Electric Lite on may need 4 or 5 flushes to clear that distance.As we reach the age where night time trips are usual I decided to stick with the manual pumped one.
As it happens since converting to the lock down pump it has performed faultlessly
Thanks for that Ditchcrawler, I hadn't thought of it from the exit strategy point of view but had wondered how to duplicate the vigorous pumping for times when things get a bit congested down the line. We had two normal electric Jabscos on the mobo that we lived on which had very powerful user controlled macerator flush pumps and also had 1" pipework on the outflow sides which I was told produced higher velocity flow than using 1.5' so was therefore more aggressive at moving things along to the holding tank ( which on that mobo was probably 20ft from the forward loo and 10ft from the owners aft cabin one). Our new sailyboat has just the one loo that is right next door to the vertical holding tank in a locker but involves an upward journey first to get to the top of the holding tank. that might help explain the mucky drainback that occurs with the electric conversion of the original manual Jabsco, that maybe it's modus operndi (and noise)doesn't encourage lengthy enough pumpout cycles. All food for thought and also making me think about simply replacing what we have with a brand new twist 'n lock manual Jabsco and using the extra money save to buy a complete new pump assembly for same to carry as an on board spare, that being easier to swap than to do a rebuild/service from a spares kit of the in situ one. Sometimes simple is best.
