Nervous about singlehanding
Single handing
It's not a problem, it helps to prepare everything in advance, for instance coming alongside and having the warps all ready on the cleats. Or at least one amidships.
Just give yourself a bit of space for every manoeuvre, because the slightest inconvenience, like say a jib sheet catching on a fitting during a tack, which would be insiginificant for the crew to sort out, can quickly become a 'Fawlty Towers Moment' when singlehanded.
A means to hold the tiller is well worthwhile. An autopilot is not necessary but can be useful. A good tiller extension so you can steer from anywhere in the cockpit is nice.
Consider how easy it is to get the anchor deployed quickly, just in case something breaks.
Sails that go up and down quickly help, so a bit of wax polish on the luff rope or sliders and track might be nice. Any other bits that fight back might be worth a bit of maintenance.
Some preventative maintenance might be repaid, those small equipment failures that are sometimes part and parcel of owning an older boat could be a lot more embarrassing with no one to steer while you fix it.
Make sure you have somewhere to stow a flask of coffee and some biscuits within easy reach of the helm, you have to be seen to have prepared!
Do it on days when it's going to be enjoyable, not as something you feel you must do.
Lots of good advice in the above answers but I would just add that you should learn how to 'Heave to' if you don't already know. It is a great thing to do to clam things down if needed, or to take in a reef, put the kettle on etc.
I would also initially go to windward or off on a close/beam reach, that way you will always get back easily, don't be tempted to shoot off downwind at first because getting back could be a struggle.
Have a good sail.
solo is not about heavy physical stuff, it's about working WITH systems and gadgets.
I agree - I single-hand a Moody 31 (sometimes) but have spent a lot of time with other knowledgeable and experienced people ensuring that the gear is arranged to make things easy. A tiller-pilot is a must-have on boats that won't keep a course without a hand on the tiller. It's little things - for example, purchases on the main-sheet traveller so I can adjust the position of the traveller under load; self-tailing winches (thankfully, she came with them!), a BIG winch handle, and so on and so on. I'm considering a trimming tackle on the main-sheet to make "tweaking" the main-sheet easier. But you see what I mean - it's about ensuring that anything that needs physical force can be done with the least effort, so you can do it without it being a big job. I can adjust the main-sheet with the existing 4-1 tackle; but when she's on the wind, it can be a bit stiff. So I look for ways of making trimming easier, so that I can keep the sail well adjusted and so make sailing easier.
By the way, I'm really AntarcticPilot, and hope they'll re-institute the separation between login name and screen name soon! I for one regard it as a security hole.
At the age of 68, having had only two hours crewing, I was hooked and went and bought my first boat, a 19 ft. Caprice. Over the winter she got a lot of fettling, including a roller-furling headsail, all lines routed back to the cockpit, etc, and I got my day-skipper theory. I've now just got my day-skipper practical, and have got a few hours sailing in, with various pals as crew. However, I'm still a bit nervous about taking her out single-handed. Any advice on my next moves gratefully received by an ancient newbie!
I have sailed my boat single handed for ages & I hav'nt got any fancy qualifications.I would just say work up to it gradually & build upon experience.There really ai'nt no substitute.That said take your boat under motor & buzz about.Find a nice empty place & a gentle day to put your sails up.Should be safe enough.......
Good timing on this thread :)
Me father is looking to go over to sail (again). He's 75. (Mostly for around the bay sailing as once or twice round the bay on a Mobo not so much fun on your todd, not at 75 - he will though be hanging onto his mobo - as figures that it will make a good holiday home in France, when he gets old :rolleyes:).................although he is still fit and active the big consideration is that he is not as nimble or strong as he used to be, and he is assuming that over time this will only change the one way.............the present thinking is trying to balance between small size, stability and ease of movement around deck. and of course price! (and for local purposes with bilge keels).....also thinking best to start something new now, so as he gets older he can trade nimbleness / strength against experiance / practice.
A westerly centaur (26') seems to fit the bill, with a drying swinging mooring..........but time will tell on how all that works out.
68? Youngster! :)
Last year after sailing a two masted dipping lugger for about 18 years often single handed I changed to a grp bermudan of similar displacent and expected the "modern" rig to be much easier to handle - it isn't, while not as much physical effort is needed I now appreciate why working boats used the rig they did. I have now just purchased a tiller pilot as, hopefully, a substitute for a mizzen while I miss the ability to quickly de-power or drop the main sail at any point of sailing when picking up a mooring or coming alongside under sail. The other aspect I am less confident about when singlehanded now is that at most times when having to go forard on the lugger if anything went wrong she would end up hove to and I knew that if the worst came to the worst I could clamber back aboard by climbing up the rudder;- I now clip on a lot more!
I did my first solo earlier this season just after buying my (first) boat, so I know exactly where you're coming from.... just one piece of advice has helped me - "take it slowly" - I know there are going to be situations where that isn't a luxury but generally I've found it to work admirably and I've been out a few times solo now...
Solo
Lots of good advice, the one about coming alongside (slowly) with a midships rope to hitch her on with is my must-do! I just gave up singlehanding a 36ft by 22ft trimaran at 69. Now I have a nice easy to handle 31ft Gaff Cutter with a 7ft bowsprit. Take all that good advice and have fun.
