Trigg732
New Member
Hi to you all and hope you are keeping safe and sound.
I currently own a Nelson 42, 1992 and am having a few problems with the electrics. I have not owned it long and I am just wading my way through the mix of factory and DIY wiring that seems to exist on her, well what do you expect for an old lovely boat.
So here is the problem......
The previous owner fitted a new 'Standard Horizon' VHF unit and when I picked her up it all worked fine, in that it would power on. The all of a sudden it has stopped working.....strange..... The unit is wired so it can be removed so I did some testing. I found that without the unit connected there was 13.7V at the connector. When I connected the unit that dropped to about 4.1V so somewhere on the circuit there is a resistance, so here is what I have done so far. -
1. The unit is wired so its removable from the boat, so I took it to be tested and serviced, it powers up on the bench drawing about 13.7V at 0.3amps
2. I replaced the DIY wiring directly by the unit, checked and replaced the inline fuses
3. I traced the wiring back to the switch on the panel by the helm and it all looks good but old
4. I took the switch panel off and tested at the switch, same thing 13.7V when not connected 4.1V when connected.
5. I replaced the switch thinking that may be causing the resistance but again the unit did not power on and dropped to 4.1V when tested.
6. I then traced the wiring from the switch back to a 'Bakelite' junction box, I have not managed to get to it to check inside as its really awkward to get to
I then noticed the shore line power cable had been split as the marina fuse kept tripping when I tried to plug her in. I then noticed that both socket ends were full of water so I have replaced the shore power lead and all is good. Ever hopeful I thought that may have solved the problem, but after about 3 hrs of charge same issue.
7. As far as I can tell the electronics and VHF radio run off of the battery bank under the helming position, I found this out by switching between the isolator switches and I have power to the VHF radio when the isolator on the engine battery bank is ON and the leisure side is OFF.
I was told the batteries were new 'ish', but looking at the terminals there is some greening on the outside of the battery pillars. I don't think its the batteries as all the other nav electrics work fine.
So I am a little stuck as to where to look and test next, I know its going to be something simple and I have missed it but I seem to be looking in the wrong place. So if any of you wiser and far more clervvvere people than me have any suggestions at all it would be greatly appreciated.
Kindest regards
Paul
Kindest regards
Paul
