Sticky Fingers
Not once your subscription has expired.
Give Gavin a call, he is a Navionics retailer, very knowledgeable helpful guy. Pm me for his numberHi all, I've just bought the Navionics App on my iPhone and I've a question if anyone knows the answer.
The depths shown on there are presumably chart datum depths (i.e. worst case scenario). I've noticed that if I click on the tides icon, I can have a real time depth from that tide (even future), which is really handy. But is there a way to have this 'real time' depth showing by default on the chart? i,e, without having to go into the tide part each time?
Thanks for any help.
Yes they are and you get quite a lot for your money. I use a dedicated laptop which I find better than a plotter.You need to buy a new chart. If you do this on expiration you get 50% off. The chartplotter charts are way more costly than the App.
I've tried every way I can, but can only get shaded areas to correspond to charted depth. What I'd like is to have a simple no go area which takes height of tide into account.I think you will find this is possible by adjusting the depth at which colours change. Explore the settings as I have done it in the past.
The way to do this is a bit fiddly and isn't sticky. Zoom out til you find a tidal arrow. Click / touch on it to select. When you do this, the shading and contours change to reflect current HOT.I've tried every way I can, but can only get shaded areas to correspond to charted depth. What I'd like is to have a simple no go area which takes height of tide into account.
Well I didn’t know that, thanksThe way to do this is a bit fiddly and isn't sticky. Zoom out til you find a tidal arrow. Click / touch on it to select. When you do this, the shading and contours change to reflect current HOT.
If you want updated charts. Yes.I am still confused, so I can’t update my card out of my plotter according to scala , so do I have to buy a new card .
If/when you get the card out plug it in to your computer and get the Garmin update app. You should get a 50% discount on stand alone price for the chart of your choice, valid for 12 month’s updates.I am still confused, so I can’t update my card out of my plotter according to scala , so do I have to buy a new card .
I don’t agree with this conclusion. The height right next the tide gauge says 1.9. Tap on the gauge and it shows 2.5 of tide but the chart depth changes to 5.9. I raised this earlier in the thread but nobody explains it.The way to do this is a bit fiddly and isn't sticky. Zoom out til you find a tidal arrow. Click / touch on it to select. When you do this, the shading and contours change to reflect current HOT.
A lead line on a yacht doing 6 kts over steep sand banks is about as much use as a chocolate tea pot.Paper chart, properly calibrated sounder and brain. In extremis a lead line.
That is odd. I tried tried this at Hurst in the Solent and it seems to work ok, you scroll through the tidal range and the charted contours change one meter at a time. Where are you seeing this?I don’t agree with this conclusion. The height right next the tide gauge says 1.9. Tap on the gauge and it shows 2.5 of tide but the chart depth changes to 5.9. I raised this earlier in the thread but nobody explains it.
On the Blackwater near Bradwell marina or anywhere else I have looked.That is odd. I tried tried this at Hurst in the Solent and it seems to work ok, you scroll through the tidal range and the charted contours change one meter at a time. Where are you seeing this?
I've just tested this using the Bradwell Waterside gauge. It seems to work OK for me so I am at a loss to explain what's happening for you. Appreciate this is an inexact science but it's not way off - within a meter or so the the sounding tracks the gauge. The reading adjacent to the gauge reads 8.9 with 5.1m of tide at HW, drops to 3.9 with 0.81m of tide at LW.On the River
