Seastoke
raymarine c80 plotter gps ,st6001 auto pilot ,st 60 tri data and what does a tri data do,there also seems to be a radar dome is this in the kit cheers roy
All perfectly good if working - there is no need to upgrade to the latest glass bridge touch screen stuff.
Tru data is your multi display that does primarily speed (log and gps if networked), depth and water temp. It does other things but those are the three (tri) main bits of info (data)
Are you sure you are not confusing the GPS dome with a radar dome?
I could be it seems big
Only thing I would add is that connectivity of future upgrades might be pretty compromised due to age. I can't recall but can the C80 take the now common NMEA 2k?
From personal experience if you try to add or change one thing ..or something stops working..you seem to end up changing much of it.
I'm sure there's the choice to route the cable through the base, or out the back to suit the installation.
Sitting at my desk in London and with the boat in the South of France I have no idea, but as it works and did so when I was last on my boat two weeks ago, I would say that it is somewhere not shown in the picture.
Where you a standards officer for the RAF as this sounds like a check ride - 'So blogs what does that bit of kit do, what is it's frequency range and what is the name of the gentleman who designed it?'
