eddystone
Has anyone fitted one of these - does it work?
That is what I fitted 6 years ago. The wire between the sensor and the readout can be extended. Excellent. Recommended.These also work just fine, plus you can connect a very loud siren to the NO - Com contacts.
12V/24VDC 220VAC STC-1000 Digital Temperature Controller Thermostat w/NTC | eBay
That's interesting, which silicon marine alarm do you have?I have a NASA one and one by these people www.siliconmarine.com in another boat both work the same but the display on the Siliconemarine one is waterproof and just over half the price.
You can just see the sensor held against the injection bend by the top hoseclip so no holes made on the exhaust. The wire is protected by a heatproof sleeve.Superheatok and Plum, Please, where and how did you fix the sender to the exhaust, inside or outside the pipe?
Www.solocoastalsailing.co.uk
Thats a great help Jamie, thanks. In regards to location where did you fit it and did you use any silicone as suggested by Silicon?
Don't worry about the actual temperature. Just fit it, go out, warm up the engine then give it a blast at close to max revs for as long as it takes to get a stable temperature reading, then set the alarm temperature 10 degrees higher.Thank you,
I see you only need the temperature of the elbow, that is easy enough to fix.
Presumably you can set the alarm temperature to suit.
The thermostat opens at 100° C, but the engine runs hotter than that.
What would be an right temperature to set for the exhaust alarm?
