ghostlymoron
Current NASA instruments have NMEA output so can interface with integrated systems.
I've had NASA instruments log & depth on my boat for years and there's nothing wrong with them, but if you're thinking about going for an integrated system on a year or two, why spend several hundred pounds on instruments that won't talk to that system?
By all means, fit a depth sounder - that's important if you aren't keen on unscheduled stops, but you don't need a log unless you're racing; the GPS in your phone will tell you how fast you're going, and the only use for a wind instrument is bragging rights in the bar - "There I was in wind over tide, the windex gave up at 55 knots... ". A multihull might need one, but your boat will tell you very clearly when you're over- or under-canvased and a simple arrow on the vhf antenna will tell you the direction if you need a hand with sail trim.
A plotter app on phone or tablet is something I would invest in now. It won't be dear and will serve you now as well as make a useful backup to your all-singing all dancing system when you get it.
