scw
New Member
Hi There,
I recently bought a sail boat that has all the electrics setup with a 12v marine leisure battery, two solar panels, it can also be connected to shore power. There is a Nasa BM1 battery monitor and everything for the last month or so has been working as it should, the battery monitor has been showing the correct inputs and outputs, battery charge etc.
We did our first sail (4 hours in fairly choppy seas) got to our location, I looked at the battery monitor and saw a flashing alarm / bell symbol and all the volts/amps that were reading correctly went to what is shown in the screenshot. The readings are with the shore power connected....
All the electronics on the boat are functioning fine, the battery is showing the correct voltage when I connect another tester tool, I even replaced the battery with a fully charged leisure battery to rule out battery issues and that made no difference to the battery monitor input/outputs. As you can see the battery percentage indicator is also reading as near empty and that since it went faulty would have always been between 80/100%.
I have looked at the cables and i can't see anything loose.
Has anyone got any recommendations to help troubleshoot the issue? I am not skilled in electronics but would like to learn how to isolate the issues so i know what needs replacing. Any advice would be much appreciated.
