NASA AIS ("radar")
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
I have a boat around 100 metres from me transmitting which I can see on Marine Traffic but there is no indication on my instrument.
As far as I can tell, the antenna is operational (by swapping below with the VHF cable).
Are there any tests I can do to find the problem?
The GPS input is missing as I have mislaid the cable but the instrument declares it is using an historical GPS position.
TernVI
8 Jul 2020
Early versions of the NASA thing were only one AIS RF channel at a time, so could lose class B vessels.
The historic GPS position could be wrong? Can it see anything else? Can you check the position? Range set to max?
The marine traffic info could be out of date, from before the other boat parked and switched off.
RAI
13 Jun 2006
Ayamonte
Does the NASA AIS Radar display an output if it has no GPS input? I have got one and I don't think it does. It needs its own position to work out where to display a received target.
GHA
26 Jun 2013
Hopefully somewhere warm
It will display all received data, it's in list view. And the manual ;)
RAI
13 Jun 2006
Ayamonte
I am away from boat, receiver and handbook. The unit needs tuning to its antenna to get the S/N ratio right. It can listen alternately to channels A and B. I now use mine only to check if my Digital Yacht AIS class B is transmitting.
vas
21 Jun 2011
Volos-Athens
which ver of the NASA black box do you have? (assuming the "radar" you're saying is 2 things, the black box and the display)
I used to have black box v2 and got a free upgrade to v3 (a DIP16 iirc chip) from NASA. That helped me see more things (again iirc) and was faster (I think!)
V.
RAI
13 Jun 2006
Ayamonte
Ah, shame Nasa didn't put that in the manual.
I had fun with it, but it persuaded me to go the whole hog and get a class B unit. In my case the class B displays targets on a SH plotter overlaid with radar targets and charts.
pvb
UK East Coast
Using AIS data on a plotter is a much better idea than the rather crude Nasa display.
Pye_End
5 Feb 2006
N Kent Coast
I quite like both. The NASA gives a very quick view of what is around without having to concentrate to make sure you havn't missed anything. It can be set on say a 8nm alarm when offshore and just left to its own devices. On the plotter there is often a lot of other data, and may well be set on a scale for pilotage. On the other hand the plotter displays contacts in a much better contextual way. I wouldn't rate either above the other.
