Nanobaro - NMEA/USB barometric sensor, easy DIY electronics project
Many thanks for taking the time. I realise that I am trying to shortcut the learning process
Is there a trick to copy and paste the code. When I copy the code in the post, it pastes without line breaks. I can add them but I am sure there is a trick that I am missing
TD
TD
Weird, I hadn't noticed that before:
I've put it on github:
https://github.com/dolabriform/nanobaro_bmp280
So now have both components and have header soldered onto the little sensor
I downloaded the code into IDE. I have installed the adafruit BMP 280 from the library
The compiler gives me an error that I not understand of course
Rather than overload the window I have copied the long error message into the attached document
Is it blindingly obvious where I am going wrong?
TudorSailor
TudorSailor
Here's the problem:
Adafruit_BMP280.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
You need to install the Adafruit Sensor library :)
Regards
David
Have you downloaded the Adafruit Sensor lib?
One of the last error lines is;
Having looked at the test for the BMP, I saw that I needed the Sensor Library. I downloaded that and then read your replies. I have run the code again and there is no error! I have now uploaded the code with no errors, so now off the OpenCPN.....
TudorSailor
If you click the little magnifying glass top right of the arduino IDE you should see the lovely NMEA messages in a serial monitor :cool:
I knew this was too good to be true. There does not seem to be data getting from the Arduino to the PC. In order to check I used IDE/tools/serial monitor and it says "error opening serial port (port busy). I have been to device manager and set the baud rate to 4800, I have left the rest of the settings alone data bits 8, parity none, stop bits 1, flow control none
TS
Even better if you use "Actisense NMEA Reader" and feed it your NMEA serial output from your Arduino/ BMP 280 you can decode the NMEA words. Or just look at the raw serial output as suggested.
TS
Only NMEA 0183 expects to run at 4800Baud. If you want to test transmission, pretty much any baud rate will work as long as the PC end is using the same speed.
TS
Is it the code from Yngmar you're using? If so, if it loaded onto the arduino OK then the computer must be talking to it. Just make sure only one program is talking to the nano over serial at the same time.
You shouldn't need to do anything to the virtual port in the device manager, just set the baud rate on whatever is doing the looking like Opencpn or the arduino IDE.
Code:
[COLOR=#000000]#include <SFE_BMP180.h>[/COLOR]#include <Wire.h>
#define NMEA_TALKER_ID "WI" // Weather Instruments
#define NMEA_DELAY 10 // Send data every 10 seconds
// meters above mean sea level
#define ALTITUDE 1
// How many samples to take per iteration
#define PRESS_OVERSAMPLING 3
SFE_BMP180 pressure;
int init_pressure() {
  if (pressure.begin()) return true;
void setup() {
  Serial.begin(4800);
  if (init_pressure() != true) {
    nmea_txt("BMP180 init fail");
    exit(1);
  nmea_txt("Nanobaro ready.");
int get_temperature(double &temp) {
  int status;
  status = pressure.startTemperature();
  if (status) {
    // Wait for the measurement to complete:
    delay(status); // Typically 5ms
    status = pressure.getTemperature(temp);
    if (status) return true;
  return false;
int get_pressure(double &press, double &temp) {
  int status;
  status = pressure.startPressure(PRESS_OVERSAMPLING);
  if (status) {
    delay(status); // Typically 26 at oversampling 3 in startPressure
    status = pressure.getPressure(press, temp);
  return false;
const byte buff_len = 90;
char CRCbuffer[buff_len];
byte nmea_crc(String msg) {
  // NMEA CRC: XOR each byte with previous for all chars between '$' and '*'
  char c;
  int i;
  byte crc = 0;
  for (i = 0; i < buff_len; i++){
    crc ^= msg.charAt(i);  // XOR
  return crc;
void nmea_send(String sentence, String params) {
  String msg = String(NMEA_TALKER_ID) + sentence + params;
  msg.toCharArray(CRCbuffer, sizeof(CRCbuffer)); // put complete string into CRCbuffer
  int crc = nmea_crc(CRCbuffer);
  if (crc < 16) msg += "0"; // pad with leading 0
  String hexcrc = String(crc, HEX);
  hexcrc.toUpperCase();
  Serial.println("$" + msg + "*" + hexcrc);
void nmea_txt(String text) {
  nmea_send("TXT", ",01,01,01," + text);
String s;
double temp, press, seapress;
void loop() {
  if (!get_temperature(temp)) {
    nmea_txt("Temperature read failure");
    temp = -1000.0;
  if (temp > -1000.0) {
    if (get_pressure(press, temp)) {
      seapress = pressure.sealevel(press, ALTITUDE);
      s = "";
      s = ",C," + String(temp)  + ",C,TEMP";
      s += ",P," + String(press / 1000.0, 5) + ",B,BARO"; // OpenCPN doesn't seem to grok Pascal (unit "P"), only Bar ("B")
      nmea_send("XDR", s);
      // These NMEA 0183 sentences are deprecated:
      //nmea_send("MTA", "," + String(temp) + ",C");
      //nmea_send("MMB", ",0.0,I,1.5,B");
    } else {
      nmea_txt("Pressure read failure");
      seapress = 0.0;
  delay(NMEA_DELAY*1000); [COLOR=#000000]}[/COLOR]
If you want some easir code just to see some messages on opencpn try this (works, just tried it), sends an NMEA once a second >
Code:
void setup() {  // put your setup code here, to run once:
 Serial.begin(4800);
void loop() {
  // put your main code here, to run repeatedly:
Serial.println("$OSXDR,P,1.0143,B,AIRP,C,18.9,C,AIRT*43");
delay(1000);
Code:
 Serial.begin(4800);
void loop() {
delay(1000);
I suspect tudor is using the hack I put on Github (which as I said I haven't tested ) for the BMP280. see post #62.
Thanks everyone! Yes I am using the code put on Github
I unplugged and turned off the laptop and rebooted. Now the arduino does not throw the COM5 connection error
The serial monitor in IDE immediately gives a few characters but not the continuous flow that I expected.
I loaded Mintaker commander to see if the pressure is displayed and it gives the message of no device found.
Any thoughts?
TudorSailor
One thing at a time! :)
Upload the code from message 75 and see if you can get data streaming with some simple code first .
Success, of sorts. I still cannot copy and paste code from the forum post directly. However as it was only two lines, easy to format. I will spell out what I did for anyone else following this thread
Serial monitor in IDE shows a stream of data in IDE. I then remembered to exit all iterations of IDE so that the serial port was free for OpenCPN
I uploaded the latest version of OpenCPN. I activated the dashboard plug in and then used preferences so that it showed barometric pressure. Now it does!
I have not moved to work out how to get a graph of the pressure which is my ultimate aim. I have tried to show the test pressure in MintakerCommander software but it does not see the COM5 input. So still on the learning curve
So I have proved that the arduino can send the right messages to the PC. Could the pressure module be faulty??
TudorSailor
Cut n paste orks OK here, paste in the code into aruido IDE then press CTRL - t which asks the IDE to autoformat the code.
In dashboard preferences in Opencpn, add barometer history.
