pvb
Indeed it is getting tedious Pete, regardeless of theory it happens, I see it happen from time to time in my daily grind ergo I know it happens from time to time and sometimes replacing the PRV does not cure it but balancing or an accumulator does, sometimes practical obsevation and memory of a decent sized sample is more useful in diagnosis than theory. The first cal is, I agree and have previously said the PRV, but it is not always the case and simply assuming it is when other factors are present e.g. the unusually high temperature expeienced in this case when all was previously OK is not the way to go. For instance I now easily exclude a PRV with a five minute pressure test so know if its that or not, so can save the time fitting one when it is not needed, and it isnt always the PRV at fault.
So you'd now agree that expansion of the water due to temperature wouldn't cause repeated large leaks in "a couple of minutes"?
