Chris_Robb
There is currently a major problem in this marina.
60% of the lazy lines are missing, and boats are having to anchor stern too the west quay. Mykonos has the reputation of being the windiest place in Greece so pay attention!!!!
The harbour has several VERY heavy ground chains running the length of the harbour. In the last 3 days no fewer than 5 boats have had to have a diver to retrieve their anchors. It is too deep for you to recover yourself as it is up to 10 meters deep in places. The cost of the diver is €100.
This morning we had a meeting with the Mayor of Mykonos and the Port Manager, which was very productive where we presented a petition signed by all the yachts in the marina.
They have commissioned a diver to quote on restoring the 36 lazy lines, which are mostly on the bottom following cutting by propellers. These were all new at the start of last year!
Following the quote, the Mayor will, (if the money is available,) authorise the reinstatement of the lines, which is not a difficult job. He hopes that it will be finished by the weekend.
They have asked all Yachts NOT TO USE AN ANCHOR IN THE PORT.
Other notes following successful docking:
Water and electric is available on the West quay in 3 places ONLY: one at either end of the yacht mooring area and one in the middle of the mooring area. It is NOT available anywhere else - all the others are switched off. You have to buy a key fob at the Kiosk at the cost of €30. The number of ports are limited to 4 x 3 = 12 water and electric points. Because of the bulk purchase - enough water and electric for a couple of weeks the points are hogged by permanent boats, however if you are lucky you will get one.
We have been allowing others to use our pipe to fill up at €3 a tank full (breaking even on cost) so try asking someone connected if you can buy water from them.
Note: The reason the others are switched off is that they were unmetered and people were using unlimited amounts to wash boats. Mykonos has a severe water shortage and most is from a desalination plant. Be reasonable in your consumption.
