Vara
Def a Tilley.
are you saying that this is not a Tilly
i fitted SP2 for tilly lamps
everything fitted as per instructions
D
Having been down to the cellar to check - it is, indeed a Tilley (it says so on the pricker knob).
The Bialaddin is green, has an integral preheater, is lower and a far more robust than the Tilley (and easier to light).
I would still maintain, however, that Dylan is too hasty and impetuous in his approach to lighting pressure lanterns.
Silly bu**ar, you pumped it too soon, before the preheater had a chance. You've probably ruined the mantle as well.
I was brought up with Tilleys and Bialaddins and still keep a couple her in the UK for those times the power-cut comes. As with so many childhood- inculcated skills I find it difficult to understand anyone having any problems with a pressure lantern. Same with reversing a trailer!!!
PS That ain't a Tilley - it's a Bialaddin and no wonder you're having problems. Two different beasts - you should have a sprung wick that clamps onto the vapouriser which you soak in meths and light. Sometimes you have to have two goes with pre-heating the Bialaddin, it's more tricky to get going than the Tilley as well as being bigger and more fragile. The only part for the two which is interchangeable is the mantle. Camping Gaz ones can be used in extremis.
This is the same lamp before Dylan got his sticky little mitts on it.
The shot of the meths burning is a cinematic tour de force.
In the same series is an equally riveting clip of a kettle boiling.
impetuous and hasty is good at 58
Despite comments about the proximity of a thatched roof, I was pleased to see that Dylan is practicing to acquire the necessary skill out in the open away from the boat. He has missed a trick, though, it was a perfect opportunity to practice using the fire blanket!
It all takes me back to dinghy camping from Calshot - they made us strip, check and polish the Primus stoves every day.
Rob.
Yes, it is difficult to distinguish red from green. I thought it was green at first, then I noticed it was red.
Note to self: Don't go sailing at night with Charles.![]()
I have one simple golden rule for lighting Tilley lamps: Preheat twice. The meths held in the standard preheater is only just and no more enough to get the vaporiser hot enough. Let it burn out. reload, relight, wait a minute and instant lighting is guaranteed.
observe the roll of kitchen paper, the big botle of meths, the small glass jar of meths and the meths covered rags
what could possibly go wrong
D
PS this is outside the back door of my thatched house
The main criticism I have of the video shown above is that the operator is shown flicking meths in the reservoir back into the jar before lighting.
Vyv, I agree except that I keep the valve just open, just so, and the plunger collar loose. When preheat is complete, I tighten the collar and pump. Once it is alight, I then remove the reservoir. I do as you do. I present the reservoir to the vapouriser filled nearly to the brim, not drained. I have three of these beasts in working order and am now restoring another 4 for some chums who have become Tilley Enthusiasts.![]()
is there a secret handshake for Tilley Enthusiasts
D
