My RM 880 gets handed over (long and lots of pics) - 2nd try!
rwoofer
1 Apr 2003
Surrey
My RM880, Hawana, has finally been handed over and so by popular demand here are some thoughts and pictures. For those that don’t know, Hawana was nearly 3 months late in handover, principally because it got damaged as it was removed from the Southampton Boat Show and ended up needing a full hull respray. Here is one part of the damage on the transom, which has already received some epoxy filler:
Here she is in the paint shop - not a sight you want to see after having seen the completed boat already:
So winding the clock forward to the day of handover, a freezing and overcast December 15th and here is my first sight of the finished boat:
Everything seems in order except the lazy bag has not been fitted. It later turns out that the dealer was unsure of the best position to attach it. A view from the aft quarter:
For a 28 foot, 3 tonne boat it’s a big 40 foot mast. Just look at the width of the spreaders - the boat next door is a Dufour 34 (a fairly racy boat) and the boat to the left is a Dufour 425. You can also see the extra long boarding ladder that I specified which allows you to easily board the boat when dried out. And a quick look at the cockpit:
I specified Raymarine tridata and wind system, which is on the left and installed a Standard Horizon CP300 chartplotter on the right myself. The CP300 is interfaced with a fishfinder, AIS, DSC VHF and the Raymarine instruments, so that I can literally see everything from the cockpit. A SH command mic will be fitted to the right of the chartplotter. At the sides you can see the running backstays (the red rope pulley systems), which contrary to the YM previews are only there if you order the staysail option. I literally ticked all the options on deck, so have the most complicated rig setup with hi-tech main/genoa, staysail and symmetric spinnaker and a furling asymmetric.
After my quick look around, we attended to some of the formalities in a nice warm office before going out for a quick test sail in 15knots of a biting easterly wind. I’ve helmed rather a lot of boats in my time, but this was the most nervous I have ever been in getting a boat out of the marina. I couldn’t even start to relax until we had got Hawana completely out of Northney Marina.
We basically did a quick zip down to Hayling Island SC and back. The day was so overcast that I didn’t get very many photographs, but here is Hawana reaching along:
And here is a picture of the rig.
Due to the wide spreaders, you don’t get much overlap on the genoa, so I specified some leech battens to maximise sail area. The main is short battened, with quite a large roach. Both are the Sobstad Platinum TD load bearing cloth, where the individual fibres are laid according to the stress maps. Here is a gratuitous picture of the chartplotter, showing the kind of speeds I’m getting used to seeing now (log hadn’t been calibrated):
We headed back to Northney, where I then discovered a diesel and coolant leak on the engine which had just been through PDC. A quick check with the engineer who couldn’t fix the problem there and then, but said it was safe enough for our trip back to Gosport. I had my father with me so at 3pm we set off from Northney to Gosport. I’m sure many would frown at us setting off for a first trip when darkness was approaching, but after such a long wait I was desparate to get Hawana “home” and my father (who accompanied me) and I have a combined 60 years of solent sailing experience. A quick close reach out of Chichester harbour and then we gybed for a broad reach all the way to Portsmouth harbour. By now the wind was blowing 20 knots, the full white sail rig was up and the waves were starting to grow – we were flying! In Hayling Bay we saw the GPS speed peak at 11 knots and we estimated that we had 1 knot of tide with us, which meant 10 knots through the water. However accurate our estimation, we were definitely planing in the peaks with the wake completely separated from the transom. My father was helming at the time and I simply couldn’t get him off – he was addicted to helming Hawana in this breeze. The helm was so responsive that I could feel every movement in the tiller being translated to the boat and as you looked forward, you could literally watch the nose dart around as the course changed. I was having to play the main in the gusts, so we were definitely overpowered, but neither of us wanted to put a reef in when we were having so much fun. The entrance to Portsmouth was incredibly rough as the tide was in full ebb and 20knots+ of South Easterly wind were creating savage wind over tide conditions - we simply powered through it all. With much relief we tied up in the dark in Haslar.
The conditions were better for the next sail, so here are a few more pictures in sunshine. Firstly Hawana in her home berth with the lazy bag attached:
A picture of the staysail set:
A view of the foredeck, which is huge for such a little boat. I can pump up the tender here no problem:
Another view of the rig, showing the fantastic sail shape. Unfortunately the main roach snags the backstays, so I need to come with a solution for that:
And finally a view from inside, whilst underway:
So my initial thoughts:
- The Handover process was a bit of an anti-climax, because I had been through so much to get the boat there. Having installed the heating and chartplotter myself, I already knew the boat very well.
- RMs simply do not let you know that they are bilge keelers. The performance, the close windedness and responsiveness are that of a good fin keeler and almost getting to race boat standards. Upwind powered up seems to deliver 6 knots fairly consistently, whereas off the wind I mostly see 6.5 knots plus.
- I specced a slightly oversize rig to maximise performance, but I really think the standard sail roaches are more than adequate. She is a powerful cruising boat.
- Under engine 2000rpm gives me 6.2 knots, 2500rpm gives 6.6knots and 3000 rpm gives 6.8knots. Suggests hull speed is about 6.5 knots, which is 1.3 * root of waterline length.
- The tiller seems relatively heavy. Partly this is because the bearings are new, but I also suspect that the rudder area (nearly as deep as the keels) is quite significant for a boat of this size and a relatively short tiller. This is most noticeable under power, where the prop wash is really felt. It may even be the case that the rudder is slightly over-balanced. Has anyone else experience this?
- Wide sidedecks and a huge foredeck make it really easy to move around the boat when underway.
- Having a tiller autopilot does seem to clutter the cockpit somewhat.
- Still don’t understand the YM comment of the loo being impossible. At 6’6” I find it more spacious than most boats of similar size, where my knees typically stop the heads door from closing. The only thing you can’t do is stand up, which is maybe what the comment refers to.
- Hawana was a deliberate downsize on my part, as I found my previous Moody 44 was really under-utilising her potential when only 2 of us were using her for mostly weekend sailing and a 2/3 week summer cruise. A 2k saving on marina fees and the reduced maintenance time of a smaller boat was my attempt at adjusting the fun/cost ratio for me and SWMBO. So far no regrets, but I need to teach myself not to look at larger boats and avoid the “keep up with the Jones” syndrome. I did feel a pang of nostalgia on seeing another Moody 44 on New Years day – she still looks a fine boat on the water.
That’s all for now. I know that at least 2 other forumites have RMs on order, so expect to see a few more around.
Congratulations richard, at last..... I hope you have many happy days with her. She looks really good, both at the pontoon, and in her natural element, creaming along at speed. Just one point, and probably of interest to other potential buyers, what was the price differential between the sails you specced and the standard ones?
You are a patient man Richard. Enjoy the boat, she looks absolutely lovely. Surprised you didnt go for the T'Gallants option /forums/images/graemlins/grin.gif Not nearly enough sail available
Now that's an interesting post and an innovative boat which I had not come across before. I'm sure you will have lots of fun this year.
I have just found the French builder's website and they only show a single spreader rig for the 880 so looks like you went for maximum horsepower!
Twin keels are not normally my thing but those keels on the website photos look like they really work and will provide great performance - I see the designer is Marc Lombard and I think he has designed Transat Minis and bigger single handed racers so a good pedigree you could say.
Does she have twin rudders and any plans to race/any idea of an IRC rating?
Congratulations and thanks for sharing the great pictures - there is nothing quite like that first sail!
"God bless her and all who sail in her" /forums/images/graemlins/grin.gif
Totally and completely Awsome..... I want one!
/forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Congratulations.
The sail shape clearly shows the advantage of going for quality laminate sails. I think however you will need to get the main recut to avoid chafing on the backstays, as it is sure to come off worse against the wire. The sailmaker should be able to calculate how much to take off for clearance.
P.S. I am thinking of one of those Standard Horizon plotters, please let us know if it really is the dogs danglies, or if there are any glitches.
Very nice! and thanks for the photos.
It may be old news, but did you see the review of YOUR boat that JJ did on Yachting TV episode 8 ?(link)
Andy
Thanks for all the kind words. Lots of questions poised, so I'll try to answer in one go:
- George, the laminate sails were about double the cost of the standard manufacturer sails, which considering how basic standard sails are is a pretty good deal. I think with smaller sail sizes the labour is a bigger proportion of the cost, therefore cloth differences have less of an impact. As you get bigger I suspect the differential widens.
- Jim, you've got me on the T'Gallants, what is it and more importantly will it fit with the blue/white colour scheme of my spinnakers?
- Racecruiser, the single spreader rig never actually happened - I think that must have been an early artist impression. She only has a single rudder, but it is very long and high aspect to act as the third leg of tripod when she dries out. Might do the RTI and a few club races, just to see if she foxes the rating systems ;-)
- Norman_E, one idea is to make the backstays fork much lower down to avoid interference with the main. Will discuss with sailmakers to get their opinion as well. On the Standard Horizon, I've not found any glitches yet, but I really need to use it a bit more for full assessment.
- misterg, did see the Yachting TV review. I tried to email them to get a copy, but had no response.
Richard
Thanks for the reminder about Yachting TV. Is anyone else having trouble downloading it? For me this episode downloads to the point where the yacht they are demonstrating coming alongside appears to be about to ram the pontoon, then it all stops! I cannot find any way of getting the rest of it to download.
It may sound a bit racy but perhaps fit a backstay flicker like the melges have? I have the same issue on my Hunter 31. Like you I went for laminate sails and had a large roach on the main which I now regret...I think I have added area in the wrong place for a rig that was heavily mainsail biased anyway.
Lovely pictures and like others, I enjoyed following your story. Reminded me of when I built and launched my boat.
Hawana looks great.Something tells me you will get a great deal of fun and enjoyment with her. Are you going to do an update now and then?
Worked OK for me the other day (Quicktime version) - Perhaps try the Media Player version rather than the Quicktime one (or vice versa)? Maybe see whether Quicktime wants to update itself?
Dunno ! /forums/images/graemlins/confused.gif
Andy
RM 880
I liked the 880 when I had a looksee around one at the factory when we were testing the 1050
Interesting what you say about the rig, the 1050 gets round the problem of the over lapping jib by having wide spreaders at the top of the rig and shorter one lower down. This enables the over lapping jib to be sheeted in between the shrouds...I'm surprised they haven't done the same on the 880
She looks like you'll have a lot of fun in her....I know I would! :0)
