pandos
Following recent storms It seems that my boat is closer to its neighbour, and to an empty mooring than I think it used to be.
I am moored in a tidal river, reasonably sheltered but am exposed mainly to SW gales, with about eight feet of water at low tide with a range of 4m approx. I have had a boat on this mooring through many storms in the past but the mooring was not used for the last 5 years. The block is 2.5 tons, attached to this is eight to ten feet of ships anchor chain, with a rope riser. It is in place about 8 years so I would have thought it was well bedded in, although it may have been lifted a few years ago when my neighbour drifted up and became entangled in my, then empty mooring.
I do not want to pay a diver or a contractor to do anything.
Two questions.
1. Is this madness.? My thoughts: drop two anchors one upstream and one downstream of my correct position. Pass a lifting sling over my deck, using a stout plank as a spreader and plenty of padding just forward of the keel and fix this to the ground chain at the bottom of the tide. When the tide rises the block will lift and I could haul myself 20m or so up river and wait till the tide drops again and then release the block.
2. How can I augment the mooring block, without getting into the water?
Thanks in advance.
Tony.
Two questions.
Thanks in advance.
Tony.
