Hurricane
That was last season
This year, I decided to simply clean and lightly polish them.
Then just before launching, I sprayed some TK Antifoul over them (only took 15 mins to spray the TK over all the metal work)
As expected, the TK Antifoul didn't do anything magic.
So now, I have come "full circle" and decided not to put any coating on them at all.
Earlier this summer, a friend showed me how to clean the metalwork quickly and efficiently.
We have always used a locally bought acid called Aqua Fuerte (literal translation "Strong Water")
In the past, we have just squirted it over the metal surface that we want to clean and then let it soak in.
Using that technique, the acid removed some of the barnacles but we have always followed up with mechanical methods.
My friend explained that a small amount of Aqua Fuerte in a pot and then using a 1 or 2 inch paint brush gently agitate the acid on the prop using a circular motion.
This way, the acid continues to work and within a short time any barnacles dissolve leaving a shiny surface.
Any previous layers of paint make this process impossible.
So, at the moment, JW has no treatment on her underwater metalwork and I've decided next season to use this process but then to polish everything as much as I can to get a slippery surface.
Our marina is a little different from most in that we get very cheap lift and scrubs - in fact most of us get one free lift and scrub each year.
So during the season, I will have the boat lifted and clean the props etc just before we go cruising.
I may even pay a little extra to have the boat left in the slings over lunch (Spanish lunch is 3 hours long!) and during that time, I can give them a little extra "Agua Fuerte" treatment.
Summarising
I think that painting the underwater metalwork with anything is just a waste of time - especially when you need to remove any old paint prior to the next treatment.
Summarising
