My Icom IC -M31 hand held vhf
Seastoke
20 Sep 2011
It turns on. But no transmission or recieve. No when I got it years ago it would not work and someone said about a display that should have an I Or U but I cannot remember any help very happy to receive.
Does the display light up when switched on? Does it look correct? Can you see/change channels, otherwise access any menu?
Is the keypad lock on?
If you turn the volume up and open the squelch (ie turn it all the way down to zero), does the speaker hiss?
Unscrew the antenna, is the little centre pin in the "rubber duck" (antenna) still there?
If the display is working, post a picture of it here on this thread. Here's the manual in case you don't have it to hand.
IC-M31 | Manual Download | Support | Icom Inc.
push the [DIAL] button for 1 second to switch between UK and International channel set, but either will allow you to transmit and receive. What can you see on the display?
Well back on the boat today , checked all suggestions, fitted spare battery and hey presto , it works . I am not saying its battery as it had display and squelch but it works . So thanks for the help.
