My DIY electric outboard.
sarabande
6 May 2005
neat. I like reversing the polarity to make the motor run backwards.
Can I beg you to wrap some tape round those rotating clips, though, please ?
Croak
18 Dec 2005
www.yotblog.com
It is just a prototype at the moment to see if the motor rotates the prop fast enough for some decent forward motion.
Sadly the motor runs faster with the correct polarity. faster backwards.
I need to find a cheap 24v controller.
Colvic Watson
23 Nov 2004
Norfolk
Would you need to vary the speed? On or off is simple enough. One use I've found for the electric o/b is helping row against a tide or wind. Set it up and it makes much lighter work of the job.
Croak
18 Dec 2005
www.yotblog.com
I quite like the two speeds 12v and 24v It would be nice to just switch between the two rather than juggle with crocodile clips and sparks
