ELJAY
So bought myself a targa 40 last August after finally giving up on my overheating and elderly targa 33 (now fixed running perfectly and on way back to uk! For sale)
Did 50 hours with no problem last season, got rid of the previous mechanic and hired a new one for the new boat - had annual service/antifoul etc - cost a kings ransom as normal and today was to be our first cruise of the new season (in Mallorca so warm and dry!) 2 minutes outside the harbour and the starboard engine alarm went indicating no charge. Stopped the engine, went into the previously pristine engine room to find that 2 belts had shredded - returned to mooring on port engine, called mechanic who replaced all four belts but when the engine was restarted (kad300) it would only go into reverse and then not disengage in neutral but by only by pushing the lever into what should be forward. No error on EDC and fuses all ok on control unit - the gears are engaging ok in control unit but obviously not in the gear box - my mechanic is returning tomorrow to lift the outdrive and take the top off whilst the boat is still in the water which sounds a little drastic - anyone had a similar problem as I can see an expensive long drawn out problem on the horizon....
