rogerthebodger
IMHO the wires should be labeled / numbered not just the terminal connection
Just do a sketch in the log book. It is not rocket science.IMHO the wires should be labeled / numbered not just the terminal connection
How do you cut a bunch of wires coming through a hole in the deck into a space in the cabin lining to different lengths so they only go in one spot? Is there no slack in the wires?Well the guard would have to be really down or the alcohol level up to get it wrong when the colours match the labels and the wires are cut to length so they only fit in one port!
Actually, in 1998 I purchased a Stella,as a project boat.Nether is numbering wire connections and has been a standard industry way of identifying all connections and both end of wiring for many years in industry.
If you make a sketch anywhere that sketch con be damaged or lost, then you are up the creak without a paddle
Use industry standards where possible
Photos are good, annotated if necessary.Just do a sketch in the log book. It is not rocket science.
